2013-11-20 6:14 AM
Hi everybody,
I'm starting working with image sensors and there is something I don't understand.ST provides a digital camera interface called DCMI. I saw some people are using it OV7670 or OV5642. But in the sensors documentation there's no reference to DCMI.Is DCMI a way to handle DVP or MIPI CS-2 or is it an interface itself?Is there a list of DCMI compatible camera sensors?I hope someone can help me, thank you very much for your attention.2013-11-20 7:25 AM
DCMI is an ST name for their interface. Basically an in-bound synchronous parallel interface. Clock sent to camera, data and framing info clocked back, data stored in memory using DMA.
Not sure there is a list. Resolution tends to be limited by the size of you acquisition buffer, either internal RAM, or external.2013-11-20 8:03 AM
Thank you very much, have a nice day.
2015-04-22 7:44 AM
Hello
I can write to registers but can't read them, what is the reason?I supply xclk pin with 42MHz sysclk coming from MCO2.Thanks.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
