cubemx
Robert Goszty?a
Associate
Posted on November 09, 2017 at 19:46
Hi
I'm using newest possible CubeMX version. Trying to generate project for some environment, in this case SW4STM32 (however tool does not matter) and got this window. Code is generated, only project cannot be done. Java installed is 9.0.1.
Checking Java output got something like this:
2017-11-09 19:40:01,978 [INFO] ProjectBuilder:1369 - Project Generator version: 2.0
2017-11-09 19:40:01,988 [INFO] ConfigFileManager:343 - The Die is : DIE410
2017-11-09 19:40:02,013 [INFO] ToolchainGenerator:103 - [Project Generator] Problem in the project generation
java.lang.ClassCastException: parsers.SysWbParser cannot be cast to parsers.FromScratchParser
at convertor.Convertor.convert(Convertor.java:546)
at convertor.Convertor.generate(Convertor.java:349)
at com.st.microxplorer.plugins.projectmanager.model.ToolchainGenerator.generate(ToolchainGenerator.java:99)
at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createToolChainFolders(ProjectBuilder.java:1408)
at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createProject(ProjectBuilder.java:508)
at com.st.microxplorer.plugins.projectmanager.engine.GenerateProjectThread.run(GenerateProjectThread.java:41)
2017-11-09 19:40:02,021 [INFO] ProjectBuilder:1424 - Time for Generating toolchain IDE Files: 44mS.
2017-11-09 19:40:02,022 [ERROR] ProjectBuilder:1430 - Error in Project Generation
2017-11-09 19:40:02,022 [ERROR] ProjectBuilder:524 - Error in Project Generation
Any help is welcome.
BR, Robert
0 REPLIES 0
