2015-07-23 8:32 AM
''The code is successfully generated under [...] but EWARMproject generation have a problem.''
2015-07-24 7:20 AM
Hi bonelli,
1- which CubeMX version are you using?2- what is your IDE version?3- could you please share your .ioc file for check?-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
