2024-01-15 7:32 PM - last edited on 2024-01-15 11:52 PM by Peter BENSCH
HI all,
I am building a system to control my battery charger.
When I power up the system from the DC power supply it work perfectly.
But when I power up this with AC power supply it gives below error.
What can be the possible error?
2024-01-16 6:10 AM - edited 2024-01-16 6:11 AM
The device uses and requires DC power. I assume by "hooking it up to AC power" you mean there is a converter to DC somewhere in there. Perhaps that converter is faulty or not doing what you think it is. More info would be needed here.
A schematic or diagram of the power scheme would be helpful. Use a multimeter to verify valid power on the VDD pins.
