2008-06-12 2:20 PM
CAN and USB sharing the same lines
2011-05-17 3:37 AM
Is it possible to have CAN and USB share the same lines to allow switching between both protocols? (They go to the same pins on the chip) I know USB requires transient voltage supression circuitry (like the USB6B1:
http://www.mouser.com/Search/ProductDetail.aspx?qs=f9uBznyCLhZlkTGf%252b8M7Kg%3d%3d
) Will this interfere with CAN? I wouldn't think so. I also have seen that CAN communication requires its own seperate transceiver. Is this an absolute necessity? What I am trying to do is allow USB programming via bootloader, then CAN communication to external devices on the same outputs (over a USB cable). Any advice/input is much appreciated.2011-05-17 3:37 AM
Suspect someone here knows - will advise.
In absence of ''tried/proven'' how about using ''2-wide'' data mux - steering STM32 pins to either USB or CAN bus components?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
