2015-01-01 11:38 PM
Hi everybody, i'm working on a custom board and experiencing a strange problem: if the two cables of SWDIO and SWDCK (they go from a stm32f4 discovery board to my board) are close Keil doesn't recognize the cortex device, if i keep them well separated everything works fine.
there is a way to have a better performance of this serial debugging feature?in my layout there is more than 1 cm between the two traces so i don't think that is a problem of crosstalk on the board.thank you so much for your help.have a good yearGio2015-02-04 1:04 AM
any help or suggestion please? i still have to debug with a finger touching the the sdio connector..it's quite unconfortable :)
thankyou2015-02-04 5:04 AM
How exactly do you have this all connected? Sounds like you don't have a good common ground between the boards/systems.
2015-02-04 7:03 AM
