Resolved! Keil IDE no space in execution regions - STM32F101RG
Hello,Due to more required space, our product shall be upgraded from STM32F101RD CPU to STM32F101RG. That is an upgrade in flash memory from 384KByte to 1MByte and in RAM memory from 48 kKByte to 80 KByte.For the STM32F101RD controller, we used the d...
KauneR by Associate III
  • 3893 Views
STM32 Release date
Hello, Could I know the release dates of the following components:STM32F103VGT6STM32F103ZGH7STM32H743ZIT6STM32H743VIH6STM32H745ZIT6STM32H745XIH6Through this page on product longevity (https://www.st.com/content/st_com/en/about/quality-and-reliability...
DSA_qb by Associate
  • 3547 Views
Resolved! Which peripherals are really in a product?
Hi,1. In the STM32G0x1 reference manual I can read about the FDCAN peripheral. But there is no STM32G0 MCU with FDCAN anyway. Why is FDCAN in this reference manual anyway?2. How can I know whether a MCU has DFU (USB bootloader)? There's no column for...
JanAtze by Associate II
  • 2813 Views
  • 6 kudos
Frequency Measurement with NUCLEO-U575ZI-Q
I'm trying to use the frequency measurement with NUCLEO-U575ZI-Q. As per suggested, the max allowed frequency of SYSCLK is 160 MHz which I use. I'm configuring TIM2 Channel 1 in direct input capture mode. I use 0 as the prescaler and the max value fo...
mebrahim by Associate II
  • 1280 Views
Do I leak enough current?
Hello,I need to know what the minimum required current is to drive a pin as input for the STM32G0-series. I've gone through the datasheet but cannot find anything concluding for me. Could someone tell me?The reason is that I use a power switch to mak...
GOjayson by Associate
  • 1822 Views
DMA Register Timer Input Capture STM32G431
Hi,I would like to measure the times and pulse lengths of an external signal from a GPIO. For this I wanted to use a DMA trigger (which writes the time points from the Tim to the memory).Here are 2 questions:1. where can I find a document that states...
pedahl by Associate II
  • 777 Views
Resolved! How memory-mapped works on STM32L4?
Hello all,I am trying to implement an external loader for my board. Which uses a W25M02GV (QSPI NAND FLASH)I am following the https://github.com/STMicroelectronics/stm32-external-loaderI am trying to configure an STM32L4 to use this memory in mapped-...
djunho by Associate II
  • 4914 Views
