VBAT Connection?
Posted on May 22, 2011 at 03:37Hi. The VL Manual (UM0919) says that by default solder bridge (SB1 VBAT) is factory set to be off. This should allow you to connect a battery to the board and run the real time clock when then board is powered off. The...
redgod9 by Associate
  • 3934 Views
IAR + STLINK : Debugger error
Posted on May 19, 2011 at 10:44Hello, I am using stm32 discovery board + IAR 6.20 + STlink USB V2 When I want to download and debug the discovery application, I get the following errors: Thu May 19, 2011 10:36:43: Loaded macro file: C:\Program Files...
IAR says it programmed STM32VLDISCOVERY, but not really ??
Posted on May 19, 2011 at 05:04OK, with help from ST and IAR's technical support, I solved the build issues in IAR related to version conflicts between IAR6 and demo code/examples written for IAR5 (see previous post). Everything builds fine now.When...
davidm23 by Associate II
  • 1492 Views
