Disabel JTAG
Posted on September 27, 2011 at 10:58Hi, I am using STM32 discovery board. I would like to use PORTB4 as GPIO, should i disable JTAG? If I disable JTAG, can i reprogrem the boad ? Thanks.
ybitton by Associate II
  • 919 Views
Open-Source tools for non-regression test (stm32)
Posted on September 27, 2011 at 12:17Hi Everyone, We would like to create a non-regression environment for our software (targetted at a stm3220G-eval eval board - stm32f2 cpu). The software involves a ethernet stack (lwip). Are there any open-source...
ADC glitches
Posted on September 24, 2011 at 18:39I have 1kohm potentiometer connected on pin PC4. On the sam pin oscilloscope is connected . Everything is correctly grounded and supplyed. On the scope (attached picture) I see 100mV glitches with a frequency of ...
matej23 by Associate II
  • 3164 Views
Use of memset and memcpy
Posted on September 26, 2011 at 11:27Hello, I am using STM32-P103 to decode NMEA sentences with some codes that they were already written and making small changes in them and I have notice that the use of functions like memset and memcpy makes the s...
sara2 by Associate II
  • 11261 Views
  • 11 replies
STM32 RTC Counter value Reset
Posted on September 27, 2011 at 10:23Hi , Im newbie about STM32 . I try to build a calendar project using STM32 discovery board. I can read counter value from RS232 port every second. I dissaamble SB1 resistor from discovery board and 3V lithium bat...
veyselka by Associate II
  • 908 Views
STM32F207 and ADC3 Problem - SOLVED
Posted on September 26, 2011 at 15:21Solved: I found a dead op-amp and some dry joints. First ever dead op-amp! But I'm not too surprised by the dry joints on the quad resistor array in a 1206 sized package. All analogs now look good!Hi, I've just s...
carl2399 by Associate III
  • 867 Views
