STM32F103ZF USB mass storage device problem
Posted on January 18, 2013 at 17:35Hello all,          I am working on a project where I need to implement USB mass storage device.  My SD card is communicating with controller on SPI2. As this microcontroller doesn't have the library for SPI so I u...
bikash by Associate II
  • 742 Views
SImple question #ifndef __STM32F100_Dicovery_H
Posted on January 18, 2013 at 02:11what is this for /**   ******************************************************************************   * @file    STM32vldiscovery.h   * @author  MCD Application Team   * @version V1.0.0   * @date    09/13/2010  ...
xtian by Associate II
  • 2746 Views
  • 11 replies
USART2 Configuration Problem
Posted on January 07, 2013 at 00:23Hi, I'm trying to read data from an external modem using USART2. PA2=RXD and PA3=TXD. The RXD only drives to about 1 volt. which is why I can't read anything. Is the following code setting up the pins correctly or...
stenasc by Senior
  • 2669 Views
DMA interrupt
Posted on July 22, 2010 at 15:25DMA interrupt #dma-irq #stm-32 #stm32-uart-usart #dma
drzile86 by Associate II
  • 2733 Views
STM32F2 SWD debug impossible [SOLVED]
Posted on January 16, 2013 at 23:42Hi at all,I read swd related post in this forum but i'm still unable to start debugging on stm32f2 chip through SWD interface. I tried with ST-LINK V2 and with SEGGER J-LINK (supporting swd), more o less with same ...
tpedef enum
Posted on January 18, 2013 at 04:33Hi guyz simple question.. Im trying to get my way in stm32 platform and I am playing around with the samples. I have this typedef enum {   LEd3 = 1,   LED4 = 0,   c0=1,   c1=3,   c2=4,   c3=5,   c4=6,   c5=7,   c...
  • 727 Views
PWM with different types of pulses
Posted on January 16, 2013 at 08:43Hello I am new to the PWM programming , I need to generate pulses of different types in a particular pattern say 80--50--20 % duty cycle consecutively at different frequencies. I am using STM32F05XXX board. Any in...
sajeed by Associate II
  • 2435 Views
BASIC GPIO
Posted on January 17, 2013 at 09:34Hi Guys, I am 1week old to stm32 programming I came from PIC1ST QUESTION // FROM Pic Basic Code normally I do this TrisC = %11111111 int data = PortC the return is the decimal equivalent of the binary or port C exa...
  • 4032 Views
BASIC USART
Posted on January 17, 2013 at 09:41Hi Guys, I am 1 week old to STM32 Platforms and I am using stm32VL and stm32f4Discovery, and it is my first time to program microcontroller in C platform I am having a hardtime understanding the sample i found in w...
  • 1955 Views
Problem with internal flash EOP interrupt
Posted on January 17, 2013 at 17:28Hi,I'm working on a project on the STM32F100 using the CodeSourcery GCC C compiler and linker in eclipse. I'm using some of the standard library from st. The project is almost done and using many timer, interrupts,...
