TIM5 and ETH_RMII_REF_CLK
Posted on December 23, 2013 at 05:25TIM5_CH2 and ETH_RMII_REF_CLK use the same pin PA1, STM32F407VG cannot remap TIM5_CH2 to other pins, I want to use TIM5 as a encoder, is there a better solution?
Posted on December 11, 2013 at 14:33Hello everyone. I'm new to programming, just got this stm32f3 board. I tried to run TIM_PWM_Input example ant it seems to work just fine. That's what i want to do now - measure external signal frequency. However, ...
Posted on December 17, 2013 at 06:46Hi Sir, I'd like to ask one question about STM32 EXIT. If interrupt pin asserted during EXT_IMR is disabled, will the interrupt be recorded by EXTI_PR and intrrupt is issued to CPU core immediately after EXT_IMR ...
Posted on December 21, 2013 at 14:53I used to the St-write to burn .bin to the STM32F4 and saw the message which I expected. Now, I hope to understand how GPIO init. Hence, I use OpenOCD and arm-none-eabi-gdb to do that. Here, it is my process.$ min...
Posted on December 21, 2013 at 22:28Hello, I try to use the ITM printf funtionality with my STM32F3-Discovery board. I follow the explanation of the STM youtube channel http://www.youtube.com/watch?v=lUPSqfO4ISk but I can't get it to work. I use kei...
Posted on December 21, 2013 at 13:35hello.I want to write byte to the sensör with I2C so write this code void MPU6050_I2C_Init(){ // RCC Configuration RCC_HCLKConfig(RCC_SYSCLK_Div2); RCC_PCLK1Config(RCC_HCLK_Div1); RCC_P...
Posted on December 21, 2013 at 00:09HeyIn order to use the user button of stm32f4 discovery as encoder mode, I was configured timer2 as follows but it didn't work: void configureEncoder(void) { RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABL...
Posted on August 30, 2012 at 16:41I have a problem that maybe someone can help with. I've spend the last few days on this and I just don't understand why it's not working. I have a STM32 where I want to send out a buffer over USART 2 using DMA to a ...
Posted on December 19, 2013 at 20:21I can't seem to find the MicroXplorer download anywhere. I can find the page, but down at the bottom there is no button or clickable item to actually get the software. I really hate asking this question...but I j...
Posted on February 01, 2011 at 09:46Where can I find the code for AN2557?
