STM32 Dac strange behaviour...
Posted on January 02, 2014 at 16:26Hello, I have been trying some waveform generation using DAC + DMA. This works quite nicely, and I am now generating I + Q waveforms for a small SDR radio project. Just to see what cand be done, I have pushed up th...
gullik by Associate II
  • 2664 Views
STM32F373CB microcontrollers with T7 grade
Posted on January 07, 2014 at 15:13According to the technical specification  a suffix 7 version part is considered as a part of the STM32F373 family. The part STM32F373VBT7 is already listed with a preview status at the STM website. Is it possible t...
victor2 by Associate
  • 960 Views
Garbage character in Usart buffer on reset
Posted on January 06, 2014 at 21:20Hello Everyone, I have been having this issue for a while on a STM32L100-Discovery board, apparently on reset there is always a garbage character transmitted to the terminal.  After the reset the USART works fine. ...
gvigelet2 by Associate II
  • 1910 Views
STM3240G-EVAL USB-HS code don´t work
Posted on January 03, 2014 at 08:17 hi, maybe someone can help me. I want test the USB-HS on my board and take the example code from the ST Homepage. After the elimination of all compiler errors and declartion of the defined Symbols, the code stops ...
STM32F41x I2C/DMA Issue
Posted on January 06, 2014 at 23:24Hi Everyone,I have written a DMA-based I2C driver that has been tested and is working reliably for normal healthy reads and writes. I get in to trouble if I try to write to a slave that does not ACK its address. In...
kenny by Associate II
  • 1101 Views
USB desvice descriptor viewer
Posted on January 06, 2014 at 12:19Hi all,I am looking for a free tool for ''USB device descriptor viewer'' running on windows.Does anyone has this kind of tool?I think there is someting from Microsoft but I didn't find it in the web.
Char array of 1024 causes incorrect behaviour
Posted on January 05, 2014 at 18:36Hi,We have a simple bit of code simply turning on an LED, however when initialising a char array of 1024 anywhere in the code the project is still built, but fails to enable the LED (or anything else, but we've str...
rowangee by Associate
  • 3101 Views
How to convert integer to string?
Posted on January 02, 2014 at 11:47struct tm time;    char year[50]; Guys, I want to display year into LCD screen but I got 00 on LCD, any clues on how to do it ? thanks  printf(''Time: %d-%d-%d   %02d:%02d:%02d \r\n'', time.tm_year, \              ...
STM32F4Discovery - Problem with EXTI portC
Posted on January 06, 2014 at 11:32In my test code below the four leds flash (as expected). The EXTI15_10_IRQHandler fires when i bring PA13 to high or to low. However when i bring PC13 to high/low, nothing happens. it took me almost a week on googl...
naquan by Associate
  • 1309 Views
