TIM1 PWM output lags [SOLVED]
Posted on March 27, 2014 at 16:23HelloMy STM32F103RBT6 has problem with PWM output (TIM2 CH4) as servo control.This problem only occuring while USART2 is processing interrupts because of received data.Interestingly, there is also some parallel with ...
zexx86 by Associate II
  • 3287 Views
  • 10 replies
Unable to get LED to toggle with STM32Cube
Posted on March 28, 2014 at 00:34 Hello, I'm evaluating STM32cube, to see how it performs. I have a simple project in IAR which I created in STM32Cube for the F407 discovery kit. Enable PortD.12 and D/13 as outputs. However when I in...
bluevault by Associate II
  • 1909 Views
How to use RealTerm with keil and stm32f4-Discovery
Posted on March 28, 2014 at 07:27Hi everyone, I've an stm32f4-Discovery kit and I'm trying to implement USART on itNow I've installed realterm, and I have my USB-to-TTL converter module.. its picture is in the attachments.. and I'm using Windows 7 ....
PWM generation in STM32F4 Discovery board
Posted on March 27, 2014 at 17:49Hello everybody.I am trying to generate a 5 PWM signals and all should look like the one below when the duty cycle is set to 50%. 4 of the signals should be generated on TIM 5 (CH1, CH2, CH3, CH4) on pins A0, A1, A2 ...
STM32F103 Input PWM TIM3_CH3/TIM3_CH4
Posted on March 27, 2014 at 10:12 Hello, I want to capture PWM input with TIM_CH3/TIM3_CH4 is that possible? Because I tried my code, and it cannot be shown when I observed the register either CCR1 for duty cycle or CCR2 for frequency. Th...
liviana by Associate II
  • 1992 Views
Generating Beep sound using PWM
Posted on November 02, 2012 at 07:01Hi all I am using stm32f2XX. I want to write a source code to generate beep sound by providing PWM input . Could anyone pls suggest me in how to proceed with this. Thanks #think! #beep #about-pwm-input
