ADC with DMA - HAL libraries
Posted on November 10, 2014 at 12:35 Hello everyone, I'm new to the forum so excuse me if I fail to hold to certain standards in my first posts. I'm currently working with a STM32F4 Discovery board using the CubeMX-generated config...
marlos by Associate
  • 2625 Views
Different USB behaviour with Hard Reset and JTAG reset
Posted on January 20, 2016 at 16:51Hello all, This problem is baffling me for quite some time. I have a STM32L151VGT6 device, running as a VCP device on USB. If I use the device with a debugger, everything is fine. I can transfer hundreds of megaby...
srdjan by Associate II
  • 877 Views
Is it possible for STM32L4 to use PMSM FOC Library?
Posted on January 21, 2016 at 13:58I'm trying to build a servo amplifier using STM32L4. The reason I'm using this series is because it has DFSDM (Digital Filter for Sigma-Delta Modulators). The FOC SDK 4.2 is not support STM32L4, however, the L4 ha...
gtopba by Associate II
  • 890 Views
STM32F0 CAN in slave mode. Is it possible?
Posted on January 19, 2015 at 07:42Hello everyone! Help me, please. I've got STM32F042K6T6. Can I use it in an endpoint device? Here is only CAN interface, is it possible to use it as slave? Thanks! #slave #bxcan #stm32f0 #slave #bus #can #can
serkodog by Associate II
  • 3317 Views
[Bug] STM32CubeMX, SAI->xSLOTR, SLOTEN not shifted
Posted on January 20, 2016 at 13:50 After spending an entire morning figuring out why my SAI configuration isn't working anymore I guess I found a new bug concerning the configuration of the SLOTR register inside HAL_SAI_Init. Prior to 1...
CubeMX and ADC Synchronous / 2
Posted on January 19, 2016 at 19:15Device:  STM32F030F4P  20 PinTool:  STM32CubeMX Version 4.12Using 8 Mhz external Crystal.  I arbitrarily set the clock configuration so that the APB1 Peripheral clock to 3 Mhz.Using ADC 1,4,6,7  -- On the configura...
