Files missing for STM32746G-Discovery
Posted on January 29, 2016 at 16:27Hi,     I am trying to measure practical speed of USB transfer in CDC device class for STM32746G-Discovery board and I can not find an example project in the cube. However, there is an example code for STM32756G_EV...
pulse sensor
Posted on January 31, 2016 at 09:54I'm trying to use thishttp://pulsesensor.com/ with stm32f10x uC.I'm not having much luck, so I just want to ask if there is someone who have some experience with this sensor and that can tell me how to set properly...
mauro2 by Associate II
  • 3201 Views
LWIP , HTTP and HTTPS,
Posted on January 31, 2016 at 17:30HelloI am gathering info for a project device that would be HTTPS client sending data to specific server, I found this AppNote for lwIP http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_...
kareemkna by Associate II
  • 2583 Views
user_diskio.c and diskio.c ??
Posted on January 22, 2016 at 10:37Guys, I tried to use SPI2 and FATFs on STM32CubeMX, but I found two files with the same function, which one should I modify to make it work ? thanks
Qestion about specific of STM32F3x core
Posted on February 01, 2016 at 06:21Good afternoon.I have problem control of disable and enable all interrupts in this processor.Compiller ''arm-none-eabi-gcc'' say me:''bridge.s:400: Error: selected processor does not support Thumb mode `mrs r2,pri...
Bug in stm32f4xx_hal_rcc.c/version V1.4.3
Posted on January 30, 2016 at 23:13See line 678 :while (__HAL_RCC_GET_SYSCLK_SOURCE() != RCC_SYSCLKSOURCE_STATUS_PLLRCLK) The intend is to  check System clock switch status (SWS field of RCC_CFGR)  after writing to System clock switch (SW field of R...
