External interrupt for trigger ADC
Posted on July 07, 2016 at 10:38 Hi I use EXTI for trigger ADC for stm32f RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); /* DMA1 Channel1 Configuration ----------------------------------------------*/ DMA_DeInit(DMA1_Channel1); DM...
Program doesn't run after Forced Bulk erase
Posted on July 06, 2016 at 23:19I have been programming an STM32f103, to get used to ARM (Olimexino board - don't laugh).I was advancing pretty well, had the GPIO working, SysTick interrupting and a basic time-banding system working.Then for some re...
How to Set Up DMA for ADC1
Posted on July 05, 2016 at 22:09I am trying to set up direct memory access for ADC1. I have already configured direct memory access for ADC3 using an example I found here: This works for ADC 3, but when I try to change the parameters to set up ADC ...
epalaima by Associate II
  • 1825 Views
Information on STM32F405 USB schematics
Posted on June 29, 2016 at 22:40I am building a board using this MCU and I'm wondering where I can get some information on the USB schematics. Reading the data sheet somewhat helped, but didn't exactly answer my question. I would like the ability to...
cradoumis by Associate II
  • 4501 Views
Getting STEVAL-ISA147V2 source code
Posted on July 07, 2016 at 16:46Hi How can I getting the source code of  STEVAL-ISA147V2 ? Is there any body to help me for getting the source code? The core of this Digital switching power supply is STM32F334C8 . The topology of this D-SMPS is LLC...
DMA, timer6 and DAC problem
Posted on July 06, 2016 at 14:48Hi, I am trying to generate analogue output using DMA. I have a taken http://vk.com/id62355309's cample code for testing. The output frequency is defined by#define OUT_FREQ 5000 // Output waveform frequency Above val...
nps by Associate II
  • 3088 Views
ADC to FFT help
Posted on July 06, 2016 at 16:38Hi, I am very new to Stm32 and i am currently using the stm32f429 discovery board. I was given a task to feed the ADC data which the signal is obtain from a signal generator into FFT to analyse the signal in frequency...
