Importing CubeMX Project Application
Posted on May 18, 2016 at 20:42I have searched this site as well as others and still find no clear and concise instruction regarding import of project applications for the various boards in the CubeMX Repository.  Specifically I am working with the ...
What is I2C Enable Listen do?
Posted on March 09, 2017 at 21:44What exactly does this mode do? I see it in the API, but I see no explanation of what it does.
achin by Associate II
  • 3672 Views
FOC 4.3 Dual Motor Control: incorrect RPMs
Posted on June 02, 2017 at 19:55Using STM32F415 for dual motor control with FOC 4.3:  ST Forum users:  FOC library is running the dual BLDC motors higher than the RPM setpoint.  I'm using setpoint values that are divisible by 6 to get the even tenth...
Resolved! SysTick calibration values
Posted on June 13, 2016 at 17:40Part of ARM's specification of the core (as given by ARM® v7-M Architecture Reference Manual, or ARMv7M ARM for short :) ) is the SysTick counter, and part of that counter is a read-only register, containing a calibr...
Regarding streams of DMA controller in STM32F429 series.
Posted on June 02, 2017 at 11:37Hello everyone,I have recently switched from 8 bit to 32 bit mcu. I'm Working on STM32F429xx series. As per datasheet of STM32F429ZI mcu (cortex m4), each of DMA controller have 8 streams. is it possible for DMA contr...
How to send data to OP-AMP and get the value
Posted on May 31, 2017 at 17:02Hello,I'm still trying to continue the programmation of my STM32F405 board and I have (again) a little problem. I use a OP-AMP to compare 2 signals by sending him a integer. The return value is always the same even if ...
