STM32_cube_LORA
Posted on August 25, 2017 at 15:17Hello , i'm using developpement kit ( B-L072Z_LRWAN ) , with the provided cube code ( End node), when downloading it, i'm expecting receiving at gateway null values for all sensors returns because there is no shield...
Kim ElQ by Associate II
  • 720 Views
External FLASH for F765 with the FMC
Posted on August 25, 2017 at 15:09Greetings All!In the past, we have used the F4 series (F427) with the FMC memory controller, to interface with 2GB of external NANDFLASH memory.  This worked with no problems.NOW, we have the same setup (same wiring...
LoRa Communication with STM32
Posted on August 23, 2017 at 13:15Hello everyone,I'm working on a LoRa project, using Murata's module ( stm32l082 & semtech's SX1276) , The aim of the project is to send some datas ( temperature, pressure .. ) to a gateway.I want to know if someone ...
  • 8990 Views
  • 17 replies
CSS is not triggering when HSE fails
Posted on April 25, 2017 at 09:21Hello,I'm using STM32F410RBT6 controller. I have configured it to use HSE with PLL (using cubeMX).I didn't soldered the quarts to the chip because i want to check that interruupt is generated when HSE fails and the C...
load2005 by Associate III
  • 2841 Views
Resolved! Problems with ADC and dma
Posted on January 15, 2017 at 21:34  The original post was too long to process during our migration. Please click on the attachment to read the original post.https://community.st.com/s/question/0D50X00009XkdduSAB/triggering-adc-in-dual-mode-with-dma...
Ernesto B by Associate II
  • 2116 Views
