USB Host MSD
Posted on April 19, 2018 at 14:35Using CubeMX is was pretty simple to make a USB host for a memory stick. When the stick is connected during power up it works.When the stick is not connected during power up it will work afer calling MX_USB_HOST_Init...
Resolved! TIM3 OC problem
Posted on April 17, 2018 at 10:00Hello , I am using NUCLEOf446re board and i have some issues with TIM3 OC getting 50Kz waveform on channel 1 . when i derive systemclock from PLL . it works fine . systemclock = 180MhzAPB1CLK = 45MHzTIM3CLK = 90Mz pr...
n.serina by Associate III
  • 2579 Views
What happened to HAL_UART_Abort in STM32F7xx_HAL_UART.c?
Posted on March 28, 2017 at 00:52The named entry point exists in STM32F4xx_HAL_UART.c, but not in the F7 version.  F7 version is about 400 lines shorter, dated 30-Dec-2016, V1.2.0, while F4 version is dated 04-Nov-2016, v.1.6.0.  Kind of complicates...
Powering up stm32
Posted on April 17, 2018 at 17:43which is best to power up    ''' STM32VLDISCOVERY '''   via 5V pins and a ground or 3,3V ???also which is best to for Digital Input for STM32VLDISCOVERY, using 5v or 3,3V ???In the data sheet I found that bouth of th...
Automatic re-join after reset or power-off
Posted on April 16, 2018 at 17:33Hi!Sorry but in Semtech Generic lora driver implementation, file MAIN.C , i need to connect the lora cube for call AT+JOIN and join OTAA network.I would like to automaticly join after reset or power off, also i think...
STM32F072RB CAN bus
Posted on April 18, 2018 at 07:17The original post was too long to process during our migration. Please click on the attachment to read the original post.
Nucleo L433RC-P UART Example
Posted on April 19, 2018 at 01:21Hi,I am new to the ST products and I am working with the STM32L433, I have an evaluation board. So, I was looking the software that you provide and for this MCU only have 5 examples. (PWR and Templates). I was wonder...
How does USB Host CDC data communication work?
Posted on April 18, 2018 at 02:11Hello everyone,I'm trying to get USB Host CDC working on STM32F407-DISC board. I'm using USB library version 2.2.0.So far, I got enumeration working fine by connecting a CDC device. I'm able to send data to the CDC d...
Pilot B by Associate II
  • 1493 Views
