Resolved! STM32H743 NUCLEO SWO printf debug issue
Posted on December 23, 2017 at 23:31I'm trying and failing to get printf debug to output via SWO on a H743ZI-based Nucleo board. I've added retarget_io.c for STDOUT via ITM Port 0 in my Keil MDK v5.24a based project. I have the ST-LINK/V2 debugger f...
pej02 by Associate
  • 2332 Views
TIM2 OC ACTIVE mode issue
Posted on June 21, 2018 at 13:47Hello I have been experimenting with OC mode of the TIMER2 and couldnt able understand the terms OCPolarity and Active and inactive mode. below trace i got from this configuration /* Common configuration for all chann...
RN by Senior
  • 1381 Views
stm32f103 tim input capture ov and iic question
Posted on June 21, 2018 at 18:181: I want capture wave every length,but in cap interrupt tim flag, i so puzzled abort that,  is  overflow judge first  or cap flag judge first,  like this, when one interrupt enter time(flags not yet judge), almost at...
Resolved! What is the use of Clock Division settings ?
Posted on June 15, 2018 at 10:00Hello, I am using TIM2 peripheral and many times f(DTS) is mentioned , what is that ?also what is the purpose of clock division settings ?does it divide the internal clock ? (CLK_INT)#stm32f4 #timer
RN by Senior
  • 3354 Views
Student project samples
Posted on June 21, 2018 at 12:01Hello,I'm Dylan from the OSCAR:QLITE team. Me and a team of 5 other students are creating a new kind of magnetometer using diamonds. We are one of the team taking part of the BEXUS campaign (organised by ESA).We are u...
Resolved! RCC PLL Timeout with -O0
Posted on June 20, 2018 at 18:00Hi,I'm facing a strange problem due to optimization 0.Actually, my code is working well but when i set optimisation to 'None' the MCU fail in its initialization.The lines concerned are in stm32l4xx_hal_rcc.c line 839....
Resolved! Printf SWO debugging in Cortex M0+
Posted on June 20, 2018 at 01:45I'm trying to use printf to SWO viewer on ST-LINK utility for debugging purposes. I'm using a STM32L062K8, which has a Cortex M0+processor. After much research on the internet, found out that ITM trace is not availabl...
Ash G by Associate II
  • 4904 Views
