Evaluation board with OpenCL compatibility
Hello guysI'm a big fan of STM MCUs and i'm recently studying parallel programming... When looking at OpenCL framework, I saw that STMicroelectronics is involved in that project https://www.khronos.org/opencl/ so, I would like to know if there is...
Hi, is there a problem with the HAL_RTC_SetDate function? If i set the year to 18, and read it back its never correct, always a year infront
RTC_TimeTypeDef sTime; RTC_DateTypeDef sDate; sTime.TimeFormat = RTC_HOURFORMAT_24; sTime.Hours = 12; sTime.Minutes = 12; sTime.Seconds=34; sDate.Date=8; sDate.Month=12; sDate.Year=20; HAL_RTC_SetTime(&RtcHandle, &sTime, RTC_FORMAT_B...
How does ST manage SVD files?
Posted on July 16, 2018 at 16:08I am still investigating on how ST manages their SVD Files.I know that i.e. they are part of Packs that then get released by Keil.But unfortunately these SVD files are not the latest versions, which I am looking for.T...
CubeMx and ST32F765BI : LSE issue
Hi all,I have a problem with STM32F765BI and LSE configuration in CubeMx : when I enable LSE in the PINOUT Panel, an erroror comes out in the clock panel and I cant set properly a value for the clock. The red box is not editable.How can I solve?Thank...
mpare.285 by Associate II
  • 2989 Views
Resolved! Beginner problem with NUCLEO-L4R5ZI and blinking LED
Hi,I'm realy new to this and I'm using NUCLEO-L4R5ZI with Ac6 System Workbench for STM32. I've found the board and initialized all peripherals with their default settings inside STM32CubeMX. Then I've generated the code for System Workbench and impor...
