Hi, I am using STM32F407ZGT6 with mikroe 1369 ( https://www.mikroe.com/mikromedia-4-stm32f4 ) I need to capture falling edge of external signal and read the time its took from starting the function till falling edge detected.
Hi, I am using STM32F407ZGT6 with mikroe 1369 ( https://www.mikroe.com/mikromedia-4-stm32f4 )I need to capture falling edge of external signal and read the time its took from starting the function till falling edge detected. I read maual but some how...
JPate.19 by Associate II
  • 3492 Views
TIM5 problem with STM32F469I
I am using 32bit TIM5 in an STM32F469I. I enable the timer and divide the 8M clock by 1000000 to get microseconds. I then use microseconds to time pulses coming into the board from external device. All works well until the timer overloads. I can ...
Crystal drive level for STM32F030
Hello, I am trying to select a crystal for a design but I am having some difficulty. The data sheet provides little information and AN2867, too much but not very useful IMO. AN2867 depends on taking measurements to determine DL and I do not have the ...
ECost by Associate II
  • 1221 Views
Can the external SDRAM address 0xD0000000 be changed ?
Hi, thereI am studying the sample codes : STM32F429I_Discovery_FMC_SDRAM and was wondering if the starting address of the SDRAM 0xD0000000 can be changed to something else. I don't see SDRAM memory section in the linker file and don't find any SDRAM ...
Eric Lin by Associate II
  • 4495 Views
Real Time Data Acquisition from STM32f407 to MATLAB
I am getting data from a current sensor through the adc of stm32f407. I want to export that data to MATLAB at real time or at least at sampling frequency of 10 kHz. I tried STM Studio but its sampling rate is only 1 kHz. So please let me know what sh...
ZRaso by Associate
  • 2064 Views
