Resolved! Question about PC13,PC4,PC5
Hi,Masterplatform:stm32f030C8TxI saw the data sheet as described below:My schematic is as follows:These LED lights can be lit at the same time, the program can also run normally, but their current sum has exceeded 3ma. Although it violates the descri...
lyu by Associate II
  • 2031 Views
Resolved! (SOLVED) STABIP in STM32F373CC never gets cleared
Hi there,I am using the STM32F373CC in LQFP48 package on my own application (not a nucleo or discovery board) with all supplies and references connected to 3.3V and decoupled as suggested by ST.The microcontroller is running as expected, I/Os are ope...
TThan by Associate III
  • 1772 Views
Whether BOR is default enabled in STM32L431 controller
Hi,I am using STM32L431 controller, I would like to know whether BOR is enabled by default or we have to write code to enable the BOR. I Assume that, by default it is enabled for threshold voltage 1.7V. Please share your input on this. ​Thank you in ...
SNaik.5 by Associate
  • 893 Views
No scroll bars in STM32MX 5 GPIO config?
First let me say I love CUBE. I make it a point now to use ST parts when ever possible just because CUBE makes things so easy. However, the last two projects I worked on had CUBE (OK, the code generator firmware under CUBE) bugs that took a while to ...
mycall by Associate II
  • 1108 Views
