Why is erased flash not reading FF
Hi community,I'm currently working on a project using a STM32L072 controller.One part ob that is implementing a customer-specific bootloader. No worries so far.What confuses me is that an empty flash reads zeroes instead of FFs. This is with the ST-L...
0690X000008A5bNQAS.png 0690X000008A5bSQAS.png 0690X000008A5bXQAS.png 0690X000008A5bcQAC.png
ABULL by Associate
  • 3261 Views
Migrate from STM32F103 to STM32F413
Hey guys,I'm currently migrating a STM32F103 project to an STM32F413 project using CubeMX.I created a new STM32F413 Cubemx project and imported the old STM32F103 project. Most settings were successfully mapped to the new MCU.However since the F1 has ...
JHeni by Associate II
  • 1483 Views
erase the entire flash memory inside the main() function ???
in my h/w, i cannot control boot0 pin to high level for dfuse demo program.however, i find that When the entire flash memory is erased, st32L4 chip automatically goes to enter usb dfu mode.hence, i want to know how to erase the entire flash memory i...
jeff.lee by Associate III
  • 1274 Views
Switching from default HSI to external HSE
Hello AllI am using Nucleo F446re. I am trying to switch my system clock from the default ​16-MHz HSI to the external 8-MHz HSE (which is already supplied as MCO by a crystal to Pin 5 of the MCU, as the schematic shows). To that end, is there anythin...
Amir1 by Associate II
  • 2731 Views
Resolved! STM32L072 power or startup issue
Hi,I recently purchased STM32L072 MCU and designed my own PCB which has the HSE and LSE crystals. I found a weird problem when I power the MCU.-Once I connect the power, it consumes 10 mA. I programmed the MCU, without any issue. But, I found that th...
ashah.16 by Associate II
  • 1691 Views
Connecting printer to stm32f4
Hi I want to connect printer to stm32f4 discovery board but i dont know form where i should start!I connect keyboard to board successfully with stmcube hid library for printer which usb host class should i select!? regards
AAgha by Associate II
  • 3090 Views
Flash memory type for STM32F103C8T6
Hello All,I am using STM32F103C8T6.it has a Flash memory of 64Kbytes.I am interested to know whether its a NAND or NOR flash. I tried going through its data sheet. But could not find explicit mention of flash memory type details.Could you please help...
