Fixed version of Cortex in STM32H7 ?
Hello,I've heard that some bugs have been found on Cortex M7 related to cache management, and that the STM32H7 will embed the fixed version of Cortex design. But I can't find when this updated version of STM32H7 will be available. Also, where (in wha...
Gpeti by Senior II
  • 2687 Views
  • 11 replies
About FMC-SRAM transmission
hi ,I have some problms about FMC-SRAM with own r&d board based on stm32h750,hope someone give me some hlps�? Now we have a strange problem that we operate on an external 16-bit bus. If we just write a word (16-bit) that is 2 bytes, the actual bus op...
HLeaf by Associate
  • 1281 Views
ADC dma interrupt stuck
I am using St microcontroller( STM32F030C6). In my project I am using ADC to measure voltage and current values. Also we are triggering DMA interrupt once the ADC conversion finish for multiple channels. Once we receive the interrupt we disble DMA an...
TAlam by Associate
  • 1389 Views
MLame.8 by Associate
  • 1066 Views
STM32L073RZ SPI 16bit data transition
I want to send 16bit spi. 8bit data is not enough because 10 bits are required.I think (uint16_t) data was the data bits which I want to change.I increased it 00 to FF but the result (SDO: Green) is quite different to what I intend. Please review my ...
MYu by Associate II
  • 659 Views
STM32L496ZG SAI1 - Wrong SAI1_FS_A
I have to read out a Mems-Mic (SPH0645LM4H-B).The Data Format is I2S, 24-bit, 2’s compliment, MSB first.One Cannel (L/R) needs 32 clocks -> Framlenght = 64Samplerate 48kHz, real 46,875kHz, Clock 3.072MHZ.Seems OK.BUT: the FS-Signal Duty_Cycle is wron...
TTimm by Associate II
  • 1738 Views
Vancouver BC event June 13
Hello I saw a Facebook ad for a workshop in Vancouver BC June 13 but when I go to register the website only lists Montreal as a Canadian location​. Is the event still happening? Is so I would like to register .​Brandon​
BSiem by Associate
  • 629 Views
