Stm32f103 counter in timer mode
Hello, I need advice. I am working on a device for revolution counting and need advice how to put the timer in the counter mode in operation with the stm32f103rb processor in order to count external pulse independently and I would like to have the re...
RP.11 by Associate
  • 1322 Views
HAL_MMC_ReadBlocks compilation error
Hi,I am using HAL driver for STM32F4 microcontroller. Every thing is fine. But, I have the following compilation error for this macro (SDMMC_STATIC_FLAGS) from stm32f4xx_hal_mmc.c. This macro was not found in the header file also. How to resolve this...
Kumar B by Associate II
  • 1202 Views
STM32L4+ OCTOSPI Memory-Mapped mode Read-Write
Hello,I'm am using the STM32L4R9I-DISCOVERY board with external FLASH memory using OCTOSPI.I wan't to use it if possible in memory-mapped mode to read and write as a persistent storageAccording to the STM32L4+ documentation RM0432 (1) it is possible...
STrop by Associate II
  • 1770 Views
How viable is production with G4 today?
I have designed and produced circuits with the F4 and L4, using plain Eclipse for development and SEGGER J-Link for both development and the ICP fixtures at the line.I have not been successful at getting J-Link Commander to play well with a G431 over...
Hi, I'm new to using nextion displays, and I have a 2.4 inch display from nextion, and I can't program to use this on my microprocessor if anyone can help me.
stm32f407zg - "https://pt.aliexpress.com/item/32827402179.html?spm=a2g0s.9042311.0.0.6c8fb90aK3A6yT"Display - 2,4 polegadas nx3224t024 "https://pt.aliexpress.com/item/32995881751.html?spm=a2g0s.9042311.0.0.6c8fb90aK3A6yT"if anyone has any library th...
Resolved! PWM Up count vs center aligned - wrong frequency
Hi ! Stm32f103 TIM3Counting: UPClock 72Mhz​Prescaler: 36-1Period: 10-1Pulse : 5​Result: 200khz 50% duty, ok !​But​​Counting: center alignedClock 72Mhz​Prescaler: 18-1Period: 10-1Pulse : 5​Result: 222khz 50% duty​Why? Schould be 200khz also.​Checked w...
oeliks by Senior
  • 2445 Views
In STM32F303RE my customer is trying to use 3 timers but problem is happening with using them at the same time as it is real time application
I am using TIM1&TIM8 for PWM generation and using TIM15 for PWM input capture mode, individually if I check in IAR TIM1&TIM8 WORK properly for PWM generation, and TIM15 properly in input capture mode, but if I use them all together after the first it...
PGama by Associate II
  • 2145 Views
LBarn.1 by Associate II
  • 828 Views
