i want to assign a number to parameter in program and check if my parameter is equal to my number , disable a pin after passing a 10 sec.in the other hand i want to make a off delay timer with HAL library .i use STM 32 AND KEIL IDE.
We are looking for SelfTest library support for STM32H7 family. Kindly share any relevant details.
Hello,we need reliability data (FIT, MTBF) for the named STM32 device.best regards
Hello,I am trying to communicate between stm32 and charger ic(bq25700a) and i am using I2C communication protocol.For that i have to transmit hex value in such a way that 8-bit LSB first and then 8-bit MSB.I am transmitting hex value 0A00, so i am ta...
Hi! I am new to stm and recently started working on Nucleo 144 board. After powering on the board, the user LEDs start blinking in different frequencies after we press the push button. I wondered if this program is preloaded on flash?
I'm trying to recreate a project we did in school on my stm32f4discovery-board. For some reason the teacher decided to load the program and the interrupt-vector into RAM. The interrupt-vector should start at address 0x2001C000. I managed to load and ...
