Errors in HAL SMBus driver for STM32F4 ?
HelloII've been working on Host SMBus mode using STM32F417 and HAL F4 version 1.25. When debugging errors on bus I found next code in function SMBUS_MasterTransmit_BTF (file stm32f4xx_hal_smbus.c line 2020)./* Call TxCpltCallback() directly if no...
IMedv by Associate
  • 778 Views
Errors while trying to port a C++ library
I'm trying to import an Arduino C++ library into an STM32F4 project. I set the project to be a C++ one while I was creating it. I've also made the necessary code changes needed for the STM32. However, while compiling I'm getting the following errors....
How to communicate with and configure the STMWBC-MC?
I am looking to incorporate STMWBC-MC in a charging dock and I am unable to locate information on programmability of this chip.I will be using a host STM32 MCU which will be interfaced with the Qi transmitter. I would like to know more about the diff...
GRang.1 by Associate II
  • 775 Views
Resolved! Having problem to understand DMA
I am trying to learn DMA properly by reading from STM32F407 reference manual . But I am confused at some points. First is about FIFO mode:- Lets say I am receiving data from UART over DMA and I am using DMA FIFO mode with threshold 1/2(that is 8 byte...
SSone.1 by Associate III
  • 2649 Views
Soil Moisture sensor i2c
Hi, I need help ...I would like to be able to read the soil moisture sensor https://tinovi.com/wp-content/uploads/2019/03/PM-WCS-3-I2C.pdf of which the arduino library exists (https://github.com/tinovi/i2cArduino) using a stm32 microcontroller. There...
