compare two char arrays
Hi thereI am trying to compare two char arrays. one is char CODENUMBER[36]="06A9062F0020063406450627063106470200";and the other one is a 250 element array called char Rcv[250]in my code, I receive messages and I fill Rcv[]'s elements with those messa...
Ala by Senior
  • 4698 Views
Resolved! How to power on a STM32H750VBTx bare chip?
Greetings,I made myself a 100-pin LQFP breakout board and soldered a STM32H750VBT6 to it. I connected all the Vss and all the Vdd. When I try to hook up SWDIO, SWCLK, 3.3V and GND from my ST-Link nothing works. The ST-Link doesn't recognize the micro...
MWeid.2 by Associate II
  • 3483 Views
Resolved! SRAM2 parity checking.
I am using an STM32L452CE. I copy an executable (.bin) from Flash to SRAM2. I zero out the remaining SRAM2. I then 'jump' to the executable now in SRAM2. When I have the parity error checking off (FLASH_OPTR_SRAM2_PE = 1) it works fine. When I turn i...
GFalz.1 by Associate
  • 1746 Views
Resolved! Where can I find a list of register names for ST32?
I recently changed the chip i'm using for a project. I'm trying to port code between an STM32F031K6 and an STM32L412K8 but some of the registers seems to be called different things. In particular any reference toADC1->CHSELR doesn't work. Where can I...
deep_rune by Associate III
  • 1777 Views
Using I2S on IT with STM32F407, I observe that the SPI_I2S IT asserting rate is not the audio sampling rate.
The IT asserting rate seems to be totally de-correlated with the rate of reception of a sample from the microphone.Has somebody already used a microphone MEMS I2S ICS-43434 by InvenSense-TDK ?I don't succeed to connect a stereo pair of this microphon...
