STM32H7 - Handling with 2 MPUs
Hello, the STM32H7 (dual core) has two dedicated memory protection units. If I configure one MPU to make a memory region only accessable as readonly, does the memory protection unit from the other core inherit those configuration or is it bypassing ...
PButc.1 by Associate II
  • 3666 Views
STM32G4 ADC Errata
Hello,For STM32G4 Rev Y:Errata 2.7.3Wrong ADC result if conversion done late after calibration or previous conversion DescriptionThe result of an ADC conversion done more than 1 ms later than the previous ADC conversion or ADC calibration might be in...
JVinc.1 by Associate III
  • 2851 Views
How to use Oversampling with H753 ADC..
I've been trying to get Oversampling working using polling for ADC completion, but I'm not seeing the expected results. I found one example for x4 oversampling, but in reality that doesn't seem to actually be doing anything. I am trying to use 32 f...
BBick.1 by Associate II
  • 1590 Views
微型太阳能逆�?�器
微型太阳能逆�?�器有评估�?�?微型太阳能逆�?�器控制软件是�?��??供给用户?或者有开�?�“微型太阳能逆�?�器�?的朋�?�和我�?�系?我的邮箱:
SQian.1 by Associate
  • 1117 Views
Need help setting up DMA on STM32F1 & F4
Hi, I am trying to set up an input capture with DMA on a F1 and a F4 chip. The documentation is confusing, and most tutorials don't work for my specific scenario. For a start, when setting up DMA using cubeMX, I can't configure source, destination an...
Ubus99 by Associate III
  • 3160 Views
Changing GPIO pin from PWM to Digital Output at run time
Hello, in STM32F10x, I need to use Stop mode. However, before going to stop mode, I need to stop PWM channels and leave them high (in output). How can I stop change some pins (A0 and A6) from timer PWM mode to normal output mode? I tried this method ...
GunkutA by Senior
  • 3745 Views
