I2C timing on STM32u385 Nucleo
Hi,I am using NCLEO-U385RG-Q  running STM32u385.  I created a project using the board selector.  I configured I2C2 using STM32CubeIDE to run in fastmode at 400khz for PINs PA6/PB2 per schematics described in MB1841.  My clock sources are all defaults...
RiyadAbd by Associate II
  • 3063 Views
Resolved! Intermittent failure when entering Standby Mode
Hello,I'm encountering an issue while testing the Standby Mode on my device.Most of the time, the device enters and wakes from Standby Mode successfully. However, after repeated testing, it occasionally fails to enter the mode.What could be the poten...
STM32Cube MX, VScode setup
Hello.I'm having issues with STM32CubeMX and VScode setup. I have the STM32 VScode extension installed and all the extras that were required as per this page ( https://marketplace.visualstudio.com/items?itemName=bmd.stm32-for-vscode ). I generate a m...
ROVguy by Associate
  • 6127 Views
  • 4 kudos
Resolved! STM32F410 flash problem
Hello, I have a problem with a PCB with an STM32F410. This board is used in the field, and in some cases, it freezes, and only works by reflashing the firmware. We're using some data in the Flash (emulated EEPROM) to write data, about 18 bytes, writt...
cleber by Associate II
  • 1112 Views
Resolved! STM32H743: QUADSPI internal timing criticality errata
Hi all,I am working on a QSPI driver for W25Q512 flash memory (extloader for stm32cubeprogrammer and main firmware driver). I had a look at the errata ES0392 - Rev 13 and I have a question about paragraph 2.8.4: 2.8.4 - QUADSPI internal timing critic...
lucky65 by Associate II
  • 1576 Views
STM32F0 railway approved
Are STM32F0 microcontrollers railway approved to use them when I'm designing rolling stock electronic component? or there is any certification regarding compliance with railway/rolling stock?
Liinda by Associate
  • 863 Views
