Resolved! STM32L0xx Comparator2
Hi everyone,I am using comparator 2 to capture a signal of duration 3-5usec. But observed that, I am able to trigger the comparator only when the duration of the signal is >5usec. I was wondering if there is any delay introduced by Vrefint in STM32L0...
CDesh by Associate III
  • 1905 Views
NUCLEO-L452RE-P problem with PC6
Hi, I have problem with NUCLEO-L452RE-P, the PC6 pin does not respond to HAL commands, other pins on Port C works, is there any way how to check what the problem might be?
LWagn.1 by Associate II
  • 2392 Views
FFT and ZCD algorithm implementation
Hello,I am using STM32L072xx, Core: Arm® 32-bit Cortex®-M0+ with MPU– From 32 kHz up to 32 MHz max.– 0.95 DMIPS/MHzI have the following questionCan I implement FFT algorithms to read ADC values?How can I implement ZCD(zero crossing detection) algorit...
  • 2317 Views
