About STM32 Network library TCP disconnect problem
Recently I ran into a problem with data loss when TCP was disconnected。​I used Keil's official Network librarynetTCP_SendReady is unable to immediately detect that the TCP has been disconnected, resulting in data loss issues​Is there a way to speed u...
YZHIL.1 by Associate
  • 933 Views
How to form Can Remote request Frame?
i want to know how to form Remote Request (frame) to get the data from host device.Is only two settings are enough (RTR bit set to CAN_RTR_REMOTE & data length = 0) suggest the whole configuration to get the data from host device.Controller suppose ...
Ss.61 by Associate III
  • 1041 Views
eMMC 5.1 / STM32F4 Compatible?
Posted on January 23, 2018 at 19:55We are looking to replace an eMMC 4.41 chip (by Micron) that we currently use with a new one SanDisk iNAND 7250-I (https://media.digikey.com/pdf/Data%20Sheets/Micron%20Technology%20Inc%20PDFs/EMMC_Series.pdf). This...
Craig B by Associate II
  • 8509 Views
  • 12 replies
Help! Nucleo-H745ZI with ST-Link, 'No target connect'
When generate the project for the CM4 core, it seems I forget to enabled the SWD debug. Now, in Keil's debug wizard, the SWDIO shows 'No target connected'. My nucleo board is just a brick now.​Any method to unlock it?BTW: I can reboot with BOOT0 pull...
Resolved! STM32F103C8 RTC SECIE: cannot enter interrupt handler
I'm trying to blink a LED once per second, using the SEC interrupt.I'm rewriting a NIXIE clock I wrote, that used a home-brewed dly() function, so the remnants of that code are still there, sorry about that.According to Ref Manual I have, if the SECI...
BGor.1 by Associate II
  • 1659 Views
