Resolved! STM32F4 chip select problem
Hello,I am having problems with SPI connectivity. My problem seems to be the chip select pin that is controlled using GPIO HAL libraries. Chip select is pulled low for way longer than it is supposed to and therefore I cannot read the sent data proper...
plate30 by Associate II
  • 4498 Views
Question about power control on STM32L476 Nucleo-64
Really new to programming these boards, and part of my project is to turn on/off these DC fans . I don't want to add any hardware to incorporate a switch, and was wondering if there was a way to program one of the power pins to be enabled or disabled...
EAmbr.1 by Associate
  • 1098 Views
Resolved! How to use DSP in STM32G070?
I have used DSP in STM32F411 successfully,but when i want to use DSP in STM32G070 , i find the DSP files are some different,such as G070's DSP files : ./Sourse/. have a Cmakelists.txt. i dont know how to use that txt file, so i just add DSP as usual...
noob by Associate II
  • 2100 Views
best way to reset circular DMA
I am sending an audio stream from memory to SAI2 on an STM32L476JG. There will be moments where I disable the DMA based on external asynchronous events. Can someone tell me the appropriate way to then reset the DMA so that when it begins again it i...
SWenn.1 by Senior III
  • 1062 Views
