lsm6ds3 registers problem
Hi everyone!I'm using a custom board with an stm32l051 and an lsm6ds3(and two 4.7kohm pull-ups). I am setuping the I2C1 (pins PB7 SDA and PB8 SCL). then I do the IMU setup in which I write some values to control registers on the IMU. then I read the ...
EPora.1 by Associate II
  • 1883 Views
Send COMP output to 2 TIMs as follower and inverter.
I want to generate differential signal from this MCU itself. I'm using NUCLEO-H723ZG doing this which has DAC, COMP and TIM built-in.I've used 2 DAC for generate 2 simultaneous UART signals (If there's other ways to do this please recommend) but it's...
AMagk.1 by Associate II
  • 1144 Views
