How to generate an arbitrary signal using DMA? (F446RE)
Hi everyone,In my project, I try to create a TTL signal generator, and I found a useful function that uses DMA on PWM signal (HAL_TIM_DMABurst_MultiWriteStart), so that I can create arbitrary rectangle signal that I want. I am using a timer frequency...
YSall.1 by Senior
  • 1672 Views
[SOLVED] STM32G070 TIM Encoder mode
Dear,I currently trying to used the timer in encoder mode.It seems to working fine whatever the mode configured.I useing the timer interrupt (Capture Compare) to read the number of step (Counter (CNT)).In mode 1 and mode 2, the CNT is decrement by 2 ...
YDann.7 by Associate III
  • 3914 Views
Resolved! What is written to the USART_BRR register?
What is this value that is written to the USART_BRR register?What is it for?I don’t understand why the calculation is done using the formula: fclock / (the divisor, in my formula it is 5 * baudrate)For example, here is an example calculation:I made t...
MMust.5 by Senior II
  • 10015 Views
  • 18 replies
STM32F405 SD DMA only works once, no matter what
Hello,I am currently trying to get an Adafruit Feather STM32F405 board to write to files on an SD card using DMA. I'm using CubeIDE, not STM32duino, and I have tried DMA configurations with both a single stream and two streams (one RX and one TX). No...
liamur by Associate II
  • 2281 Views
STM32H743 PWM
hello friends)))) I bought a new stm32H743 for familiarization and got confused how to implement PWM on HRTIM. I'm trying to do PWM on timer B. configured GPIO_PC8 to AF1 in GPIOx_AFRH. everything is fine there.HRTIM_B_PERxR==2000 HRTIM_B_CMP1xR==200...
MTS by Associate II
  • 2853 Views
