Resolved! I recently ported my STM32F413 (run at 100Mhz) application to a STM32H7A3 (run at 280-Mhz). But my DSP routine does not run 2.8x faster. Anyone has any idea how this happened?
I measured the time took to run a length 127 Multiply–accumulate routine by togging a GPIO pin before and after the arm_dot_prod_q15() routine. And then I can measure pulse width by a scope. It was 7us on the STM32F413 and 6us on the STM32H7A3.
nNg.1 by Associate II
  • 5327 Views
  • 10 replies
Resolved! STM32 Availability for new designs
I have several eval boards and was interested changing to ST platform prior to pandemic. Now looking at getting back to it, but checking with Mouser, Digikey, etc.. and nearly all of the STM32F4... parts I would be interested in using are still out ...
FJB2069 by Senior
  • 3462 Views
Stm32G431C8U6 SPI2 HardFault.
Hi,I am working on a project with STM32G431C8U6. My code always goes to HardFault Handler. I created a new project for testing my MCU just an easy code, code went to HardFault again. I share my ScreenShoot's please help....
Ydemi.1 by Associate
  • 1773 Views
RM0394 references to non-existing SAI2
I understand that there's a great deal of copypasting when creating RMs, but can ST please pay more attention to the details?In particular, no part described by RM0394 should have SAI2 implemented:yet there are references to SAI2 through the document...
Problem with triple adc Regular simultaneous mode with DMA
Hi, I am trying to set up simple example project with DMA and triple adc working together. What I am getting is that DMA interrupt is only activated once - I verified all the data is trasfered as supposed to. But, next time I start ADC in the for loo...
VRakc.1 by Associate II
  • 3324 Views
STM32 encoder mode sample rate
Hello,I'm working on a STM32 project which use the timer in encoder mode.TIM2 of my STM32F103C8 is set in Encoder Mode, I've enabled the TIM2 global interrupt.I'm evaluating the counter at each interrupt.Prescaler is 0, Counter Period is 65535.Main c...
How are MCUs tested for temperature rating?
Hi!I was wondering if anyone has any insight into the temperature rating testing for the STM32 MCUs.Particularly, how can ST establish if a MCU is rated for 85*C or 105*C and how are those differentiated in the manufacturing process?Are MCUs which ar...
MMicl.1 by Associate
  • 1497 Views
