2023-11-03 11:35 PM
2023-11-11 5:43 AM
I have exactly the same issue. If you use the Simulink Coder Support Package for STMicroelectronics Nucleo Boards the XCP issue is solved, however the package does not have support for hardware interrupts and PWM generation using timers.
2023-12-15 2:09 AM
I am using embedded coder for STM32G474 board and I don't use External Mode, so I just Build and Deploy from Simulink, but the debug is made through SPI.
Have you considered using an external USB-TTL for "External mode"?
Then you would launch the app, and then Monitor. You only loose the Tune capability.
