User button use
UniRob
Associate III
How to use in main.c the user button of B-G431B-ESC1 board ?
I want to togle the position each time I press (amd release) the button.
Waiting for target position completed and than I can press the button again.
I have selected the PC10 pin in MXCube that originate this code in main.c:
/*Configure GPIO pin : PC10 */
GPIO_InitStruct.Pin = GPIO_PIN_10;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
in main I write this code, but nothing happen.
Where is the problem ?
if ( GPIO_PIN_10 == 0 )
while (GPIO_PIN_10 == 0)
Pos = MC_GetCurrentPosition1();
if ( Pos == 0.0 )
Pos = 314.159;
else
Pos = 0.0;
MC_ProgramPositionCommandMotor1(Pos,1.5);
while ( MC_GetCurrentPosition1() != Pos )
1 ACCEPTED SOLUTION
Accepted Solutions
Andrew Neil
Super User
Please use this button to properly post source code:
GPIO_PIN_10 is a constant: it just identifies the pin - it does not give you the current state of the pin.
To read the current value of a pin, use HAL_GPIO_ReadPin():
https://www.st.com/resource/en/user_manual/um2570-description-of-stm32g4-hal-and-lowlayer-drivers--stmicroelectronics.pdf
See also AN5315STM32Cube firmware examples for STM32G4 Series:
https://www.st.com/resource/en/application_note/an5315-stm32cube-firmware-examples-for-stm32g4-series-stmicroelectronics.pdf
https://www.st.com/en/embedded-software/stm32cubeg4.html#documentation
https://www.st.com/en/microcontrollers-microprocessors/stm32g431cb.html#documentation
2 REPLIES 2
Andrew Neil
Super User
UniRob
Associate III
Perfect now is running.
Thank you.
