2021-12-28 3:34 AM
i'm using the a STEVAL-IHM034V2 board for evaluation (PFC + FOC PMSM).
i am using three phase induction motor
well I am using the Motor Control Workbench 5.4.7, for generating code , Keil uVision5 for burring the code in Controller , the code is burned through STLink, its burned
but the motor is not started, even not getting the voltage at the output,
PWM is not working , and Inverter part also not working
motor workbench is connect through serial communication , and opened the monitor window and connected, but still not working
need your support and help to operate this board
Thanks a lot in advance
Thanks and Regards
Mudassar
2021-12-31 7:09 AM
Dear @MAhme.5
Have you looked at https://wiki.st.com/stm32mcu/wiki/STM32MotorControl:SDK_AC_induction_motor ?
Best regards
