2025-01-06 1:51 AM - last edited on 2025-01-06 2:47 AM by Andrew Neil
I bought the STEVAL-ETH001V1 kit on digikey. I also downloaded the firmware for the servo drive. However, when I build this project using keil c, the "TrajCtrl.h" library is missing and this library is not provided in the firmware.
I would like to ask where I can find this library or can someone help me?
2025-01-07 8:03 AM
Hello @phamtutailtvm,
Loading project on IAR, PositionDemo.c file, that uses TrajCtrl.h file, is not part of the project. Could you try without it?
2025-01-07 8:03 AM
2025-01-07 11:38 PM
Why don't you provide that file in the firmware? I use Keil C to run and debug for my project. So i need that file to continue my project.
If possible, can you provide me that file?
