2023-12-19 3:45 PM - edited 2023-12-20 7:21 AM
I installed MCSDK 5.4.8 and CubeMX 5.2, which runs, so, if it uses Java, a suitable version must be installed.
But when I try to Generate from a MotorWorkbench project, it gives me this error:
Generation process failed. The embedded JRE was not found. Please check the correctness of installation.
How do I fix this problem? [I assume I can't just install any JRE willy nilly]
