2023-10-04 8:11 PM
When I want to generate a project, this error stops me.
Is there any installation steps that I skiped?
2023-10-05 1:14 AM
Hello @BurnNavy ,
I proposed a solution in this post: Solved: MotorControl reference pack not found: "../../../.... - STMicroelectronics Community
but i recommend you to use version 6.2 of the MCSDK on which the B-G431B-ESC1 board is supported.
2023-10-04 8:22 PM
By the way, the development board is B-G431B-ESC1. There is the project created, however, I can't open most of the files.
Should I change to MCSDK 6.2.0?
2023-10-05 1:14 AM
Hello @BurnNavy ,
2023-10-05 1:51 AM
Hello @Zied b.
Thanks for your solution.
Honestly, I don't understand the post. Fourtunately, "generation" works after using 6.2.0.
Is there any manual explaining the code?
2023-10-05 1:55 AM
Hello @BurnNavy ,
You have the explanation on how to access the documentation by following this link:
MCSDK documentation and your feedback - STMicroelectronics Community
If you have other questions regarding ESC, you can use the forum search bar, many topics talk about ESC
