2016-09-15 2:22 PM
I have been trying to use FOC SDK 4.2 with existing hardware. The board uses inverting amplifier instead of non-inverting ones. Anyone got an idea on how to modify the code?So far I've tried:1. use negative value for amplifier gain: doesn't work2. use negative value for current shunt: doesn't work3. use negative gains for the current loops: stable current loop, but will trigger ''speed feedback'' fault.Thanks!2021-06-15 12:22 AM
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
