2025-11-18 4:45 AM
Hi, I'm using the boatd ihmi08. I would like to control the motor in closed loop as a target rotor angle. Is it possible in 6 steps or is the focus much better?
2025-11-18 4:46 AM
Foc not focus!
Im using naturally incrementale encoder
2025-11-18 5:06 AM - edited 2025-11-18 5:06 AM
In my opinion since encoder is supported by hardware, FOC is better since you know the rotor position accurately and FOC can generate accurate torque control.
2025-11-24 8:33 AM
Hello @SDall,
Using Quadrature Encoder speed sensing, FOC mode provides a position control mode. Refer to the Position Control chapter of the User Manual available through Workbench tool > About > Documentations > Documentation.
You can also refer to the Position Control application note.
