STM32 MCUs Motor control
GMA by ST Employee
  • 1839 Views
MCSDK 6.4.0 is out!
GMA by ST Employee
  • 4993 Views
Zied b. by ST Employee
  • 9747 Views
Cant generate project
Hi, firstly I installed java 8 and I installed STM32Cubemx 5.6. after that I installed X-CUBE-MCSDK. But gave message in the setting of the project generation that "STM32CubeMX not found - ver. "5.2.0" or higher is required".
mkk.1 by Associate II
  • 1440 Views
How to calculate the overcurrent limit in case of STEVAL-IPM08B and STEVAL-IPMNG8Q: Diodes in OCP path?
I am trying to select a board for evaluation for a High Voltage motor control application. Selecting the STEVAL-IPM08B in X-CUBE-MCSDK v5.4.3 shows OCP limit as 8.3 Amps while the STEVAL-IPMNG8Q OCP limit is shown as 12 Amps. This seems strange as th...
B-G431B-ESC1 as DC motor driver
Hi.I have been exploring the options on how to use the B-G431B-ESC1 board to drive a DC motor and so far I have also succeeded in doing so manually by reflashing the firmware with a custom one.Unfortunately I am struggling with getting the current me...
