STM32 MCUs Motor control
GMA by ST Employee
  • 1838 Views
MCSDK 6.4.0 is out!
GMA by ST Employee
  • 4992 Views
Zied b. by ST Employee
  • 9745 Views
Wrong period values during motor startup.
I am making a BLDC motor controller using STM32G030C8t6. This microcontroller has a hall sensor sensing capability known as ‘Hall Sensor Mode / XOR Mode’. This generates an interrupt when any one of the three channels toggle. We are taking the timer ...
Gladson by Associate III
  • 3039 Views
Calculating DC Current drawn.
I tried searching for documentation to help me Calculate Current from set reference current in dpp unit.Can anyone kindly give simplified explanation on how to convert current from dpp to Ampere (DC) ?For the purpose of calculation..Or share a good d...
Muthanna by Associate III
  • 957 Views
g071rb+ihm07m1+bul lrunning motor
I am experiencing issues while trying to operate the BR2804 1700Kv BLDC motor with the IHM07M1 motor controller and either the L476RG or G071RB board. we are just using the software like cube mx , cube ide to genarate code . while using L476RG , all ...
#iR by Associate II
  • 1604 Views
Resolved! How to switch between "CurrentSensing" hwVariants?
We are working on a custom inverter board based on a B-G431B-ESC1.As we want to have the option to choose between Single-Shunt and Three-Shunt variant for current sensing, I implemented both features as hwVariants, according to the documentation.See ...
DMeie.2 by Senior II
  • 1898 Views
MotorControl Workbench 5.Y.4 Problems
Hi Community,I just start desiging a AC induction motor driver with motor control workbench 5.Y.4.But I have some problem about it. I can not generate code. I had try many ways but always same result. Its finished with "Comleted with errors" message....
Mnemonic by Associate III
  • 5099 Views
AC Servo Motor with STM32f407
Hello guys, I'm looking to control an AC Servo motor with STM32f407- Discovery kit. There are a lot of resources for DC motor, but i couldnt find many for AC Servo. Can anyone suggest on how to approach or share me some resources? Thanks in advance.
MCSDK
Hello, I am using a G030C8T6 MCU with mcsdk version 6.2.1 and the latest version of cubemx to create a motor program, but with the G0 chip library version 1.6.2 and 1.6.1, it creates the bus voltage sampling incorrectly, and it is only correct if I a...
iskan by Associate III
  • 1285 Views
MCSDK 6.2.0 bug - Virtual V_bus_sensing
When disabling Bus Voltage Sensing and Temperature Sensing in MC WB 6.2.0 the MC Application results in HardFault. After some debugging I found that the last release of the MCSDK has made a minor change to RCM_ReadOngoingConv(). This means that when ...
Motor drive product recommendation
Hi, I have an electric assist power steering column I have been working on building a control module for. It uses a 630w IPMSM motor with hall sensors and has a supply voltage of 12-14V DC. I have managed to get the motor to run with a G431-ESC1 and ...
TRowe by Associate II
  • 1305 Views
