2021-03-16 7:58 AM
is it possible to use this board with an axial magnetic position sensor ( instead of HAL sensors) , such as AS5147U (from AMS)?
2021-03-18 12:21 AM
The magnetic position sensor AS5147U has incremental outputs.
So there should be no problem.
2021-04-18 10:32 PM
AS5147U has an ABI mode (A and B for quadrature encoder and I for index also sometimes denoted by Z). So you can use it by connecting A and B outputs to H1 and H2 inputs (board should have solder pads instead of physical connector) and select Encoder in Speed Sensor.
