2014-09-28 2:46 AM
STM32f407 + usb3300, work in host mode, some high speed usb devices work very well. However, I try for some days to detect vbus over-current, but failed. Has anybody implement it successfully?
My hardware logic is in attached file. My software is as followings.globle reigster GUSBCFG=0x21301410, the lower 16bits is hw default, the higher 16 bits meaning: force host mode, indicator pass through, external vbus indicator external vbus driver,port status is 0x00001005, and interrupt is always enabled.I try all measures, even short-circult vbus to ground to try to make a over-current condition, but nothing happens in usb core register and software interrpt. #usb-host2014-10-16 3:00 AM
You can try to disable SRP interruption..We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
