2024-08-01 1:18 PM - edited 2024-08-02 3:25 AM
Hi
in different posts in forum I read ST's USB library is not thread safe. There are no examples with USB CDC and FreeRTOS.
Is that true?
Thx
2024-08-05 1:51 AM
Hi @MK..1
ST USB middleware is not explicitly using malloc() and free(), but it is crucial to configure it to use static memory allocation to ensure thread safety.
* @brief Static single allocation.
* @param size: Size of allocated memory
* @retval None
void *USBD_static_malloc(uint32_t size)
static uint32_t mem[(sizeof(USBD_CDC_HandleTypeDef)/4)+1];/* On 32-bit boundary */
return mem;
* @brief Dummy memory free
* @param p: Pointer to allocated memory address
* @retval None
void USBD_static_free(void *p)
2024-08-01 2:29 PM
Yes. If you don't know why your software works, you have a potential risk.
2024-08-02 2:18 AM
Hi @MK..1
Usage of malloc(), free(), or any other function implicitly calling these functions is not safe in multi-threaded systems even in bare metal or RTOS systems. AN5731 provides some guidelines for ensuring thread safety.
2024-08-02 3:21 AM - edited 2024-08-02 3:26 AM
Hi @FBL
how does AN5731 relate to ST USB library as it is not using malloc()?
I didn't find any malloc or free in the ST USB library!
Is there a specific reason why there is no CDC and FreeRTOS example project?
Thanks
2024-08-05 1:51 AM
Hi @MK..1
* @retval None
return mem;
* @retval None
